  • Login
  • Register
  • Login Register
    Login
    Username/Email:
    Password:
  • Home
  • Help
  • UZ Energy Portal
User Links
  • Login
  • Register
  • Login Register
    Login
    Username/Email:
    Password:
    Quick Links Home Help UZ Energy Portal
    UZ Energy Community DIY Hardware EcoNode, OpenEMS Edge Hardware EcoNode Series Gateway CC++ Development Guide -development environment
    • 0 Vote(s) - 0 Average
    LeoXu
    Offline
    Junior Member
    Threads: 12
    #1
    09-19-2024, 10:34 PM (This post was last modified: 09-19-2024, 11:07 PM by LeoXu.)
    Connect EcoNode to a PC
    To connect EcoNode to a PC via LAN1, configure the PC’s wired network card address as follows:
    1. Connect the EcoNode smart gateway's LAN11 port to the same switch as the PC, or directly connect them using an Ethernet cable.
    2. Modify the PC's wired network card IP address to be in the same subnet as the gateway (192.168.3.XXX).
    3. If the PC lacks an Ethernet port, you can use a USB Type-C to Ethernet adapter to make the connection.
    PuTTY
    To remotely access a Linux server using PuTTY, follow these steps:
    1. Open PuTTY: Launch the PuTTY application on your Windows machine.
    2. Configure Connection:
    a.  Host Name: Enter 192.168.3.105.
    b.  Port: Set to 22 (default for SSH).
    c.  Connection Type: Select SSH (Secure Shell).
    3. Login:
    a. Username: Enter uzenergy.
    b. Password: When prompted, input ******.
    [Image: 20240920143234.jpg]
    .pdf   EcoNode Series Gateway CC++ Development Guide -development environment.pdf (Size: 955.68 KB / Downloads: 171)
    LeoXu's Signature
    Limited Partner of UZ Energy
    YouTube: UZ Energy
    EcoNode promoter
    OpenEMS fans
    OpenBMS fans
    « Next Oldest | Next Newest »
    Users browsing this thread: 1 Guest(s)
    • View a Printable Version
    • Subscribe to this thread
    Forum Jump:
    UZ ENERGY LIMITED
    Home · Members · Team · Help · Contact
    Marketing@uzenergy.com
    About UZ Energy UZ Energy is a global provider of premium energy storage systems.
    Linear Mode
    Threaded Mode
