  • Login
  • Register
  • Login Register
    Login
    Username/Email:
    Password:
  • Home
  • Help
  • UZ Energy Portal
User Links
  • Login
  • Register
  • Login Register
    Login
    Username/Email:
    Password:
    Quick Links Home Help UZ Energy Portal
    UZ Energy Community Tech Vision & Support General Lithium-ion Battery Pros and Cons of Active Balancing and Passive Balancing
    • 1 Vote(s) - 5 Average
    Pete_UZ
    Offline
    Senior Member
    Threads: 123
    #1
    12-22-2022, 07:40 PM (This post was last modified: 12-22-2022, 08:19 PM by Pete_UZ.)
    Presented by UZ ENERGY, follow us via LinkedIn, Twitter and YouTube.
    Passive balancing results in all battery cells having a similar SoC by simply dissipating excess charge in a bleed resistor; it does not, however, extend system run time. Active cell balancing is a more complex balancing technique that redistributes charge between battery cells during the charge and discharge cycles, thereby increasing system run time by increasing the total useable charge in the battery stack, decreasing charge time compared with passive balancing, and decreasing heat generated while balancing. Generally for low power application (RESS and small C&I ESS Application) the Passive Balancing BMS is good with its low cost, small size and very simple control. Click for more
    Limited Partner of UZ Energy
    YouTube: AK's Tech Studio Channel of fancy tech (content in Mandarin Chinese)
    « Next Oldest | Next Newest »
    Users browsing this thread: 2 Guest(s)
    • View a Printable Version
    • Subscribe to this thread
    Forum Jump:
    UZ ENERGY LIMITED
    Home · Members · Team · Help · Contact
    Marketing@uzenergy.com
    About UZ Energy UZ Energy is a global provider of premium energy storage systems.
    Linear Mode
    Threaded Mode
