Step-by-Step Guide for Beginners: Setting Up OpenEMS Simulation Configuration - Printable Version +- UZ Energy Community (https://forum.uzenergy.com) +-- Forum: DIY Hardware (https://forum.uzenergy.com/forumdisplay.php?fid=52) +--- Forum: EcoNode, OpenEMS Edge Hardware (https://forum.uzenergy.com/forumdisplay.php?fid=53) +--- Thread: Step-by-Step Guide for Beginners: Setting Up OpenEMS Simulation Configuration (/showthread.php?tid=340) |
Step-by-Step Guide for Beginners: Setting Up OpenEMS Simulation Configuration - LeoXu - 11-19-2024 # **OpenEMS Simulation Configuration Steps** This guide provides step-by-step instructions for setting up and debugging OpenEMS simulations. --- ## **Step 1: Simulator App** - **Action**: - Check `enable`. - Click `save`. - **Notes**: - This will clear all existing configurations. Ensure no critical data is lost before proceeding. - After clearing, all essential settings must be reconfigured in sequence. --- ## **Step 2: Scheduler (All Alphabetically)** - **Settings**: - `ComponentID: scheduler0` - Check `enable`. - Click `save`. - **Functionality**: - Automatically starts the following core components in alphabetical order: - `core` - `ess power` - `evcs power` - `Controller Api Websocket` - `log` - **No additional configuration required** to ensure basic system functionality. --- ## **Step 3: Controller Debug Log** - **Settings**: - `ComponentID: ctrlDebugLog0` - Check `enable` and `Condensed output`. - **Functionality**: - Enables debugging mode with condensed logs for troubleshooting and system analysis. --- ## **Step 4: Simulator DataSource (CSV Predefined)** Configure three data sources to simulate load, PV generation, and ESS data. 1. **Load Meter Data Source**: - `ComponentID: datasource0` - Configuration: - Check `enable`. - `Factor: 10000` - `Time-Delta: -1` - `Source: h0-summer-weekday-standard-load-profile.csv` 2. **PV Meter Data Source**: - `ComponentID: datasource1` - Configuration: - Check `enable`. - `Factor: 10000` - `Time-Delta: -1` - `Source: h0-summer-weekday-pv-production.csv` or `production2`. 3. **ESS Data Source**: - `ComponentID: datasource2` - Configuration: - Check `enable`. - `Factor: 10000` - `Time-Delta: -1` - `Source: h0-summer-weekday-pv-production2.csv`. --- ## **Step 5: Simulator GridMeter Acting** - **Settings**: - `ComponentID: gridmeter0` - Check `enable`. - **Functionality**: - Simulates grid monitoring, providing data on grid power, state, and flow direction. --- ## **Step 6: Simulator EssSinglePhase Reacting** - **Settings**: - `ComponentID: ess0` - `Phase: L1` (single-phase setup; use L2 for two-way or L3 for three-phase setups). - `Datasource-ID: datasource2` - `Max Apparent Power [VA]: 10000` - `Capacity [Wh]: 10000` - `Initial State of Charge [%]: 30` - `Grid mode: On_Grid` (enables grid interaction). - **Functionality**: - Activates a single-phase ESS to simulate power response. --- ## **Step 7: Controller Ess Balancing** - **Settings**: - `ComponentID: ctrlBalancing0` - Configuration: - `Energy System ID: ess0` (matches Step 6). - `Grid Meter ID: gridmeter0` (matches Step 5). - `Target Grid Setpoint: 10`. - **Functionality**: - Controls ESS and grid meter to maintain balanced power flow. --- ## **Step 8: Controller Api Websocket** - **Check**: - Ensure WebSocket is enabled. - **Functionality**: - Facilitates communication between OpenEMS and the UI. - The UI will not display system status if WebSocket is disabled. --- ## **Step 9: Simulator Battery** - **Settings**: - `ComponentID: bms0` - Check `enable`. - Configure parameters: - `Number of slaves: 1` - `Discharge min voltage: 44` - `Charge max voltage: 56` - `Discharge max current: 50` - `Charge max current: 50` - `SOC: 75` - `SOH: 95` - `Temperature: 30` - `Capacity KWh: 50` - `Voltage: 5` - `Min cell voltage mv: 3300`. - **Functionality**: - Activates the battery simulator with customizable parameters. --- ## **Step 10: Simulator NRCMeter Acting** - **Settings**: - `ComponentID: meter0` - Check `enable`. - Configuration: - `Datasource-ID: datasource0`. - **Functionality**: - Activates load meter simulation, linked to `datasource0`. --- ## **Step 11: Simulator Production Meter Acting** - **Settings**: - `ComponentID: meter1` - Check `enable`. - Configuration: - `Datasource-ID: datasource1`. - **Functionality**: - Activates PV meter simulation, linked to `datasource1`. --- ## **Additional Recommendations** 1. **Step-by-Step Validation**: - Save after adding or modifying each component. - Use the OpenEMS WebSocket interface to verify component statuses incrementally. 2. **Log Monitoring**: - Enable debug logs (Step 3) for detailed analysis of system interactions. 3. **Simulation Flexibility**: - Adjust parameters like battery capacity, power limits, and load curves to better simulate real scenarios. 4. **Advanced Features**: - Use custom data sources or scripts for extended simulation, e.g.: - EV charging load simulations. - Fault condition testing (e.g., disconnections, overload). By completing the above steps, the simulation system will be ready for testing and validation of complex scenarios. ![]() |
